92olds
Old 12-10-06, 06:30 PM
92olds
have 92 olds cutless ciaira 3300 will not run it will start with starting fluid changed fuel pump still wont start do you know were the safty shutoff for fuel pump is lokated this car died when it was driven thrugh water
Old 12-10-06, 07:52 PM
it doesnt have a safety shutoff, would be looking at the fuel pump relay or maybe even the ecm to see if its turning the fuel pump on.
Old 12-14-06, 06:27 PM
92 olds cut ci
where is the ecm and the fuelpump relay located and how would i check them
Old 12-15-06, 07:04 AM
if you know the fuel pump isnt getting power and you dont hear it when you turn the key on would check the relay for starters it should be under the hood passenger side, the ecm is inside the car passenger side either under the dash or behind the glove box.
you may need a wiring diagram to test the relay if your not familiar with how a relay works.
