Dash Lights Not Working
Old 12-11-06, 12:45 AM
What are the likely causes for the dash lights to be out on a 1991 Buick Regal. All other lights work and the light switch is fully clockwise. Also, can a "jump" start cause this problem. Thanks.
Old 12-11-06, 03:42 AM
My first guess would be to check the fuse block for a bad fuse, but it could be a bad switch dimmer.
Old 12-11-06, 09:24 AM
On the '88 Regal it is a 5 amp fuse in the fuse block. Probably the same for your '91 Regal.
Old 12-12-06, 03:39 AM
I'm not familiar with your Buick but most switches are off when turned clockwise and on when turned counter-clockwise. Have you tried turning the switch back and forth several times?
