service engine light
Old 12-16-06, 10:13 AM
WHEELERBUFFY's Avatar
after changing oil --service engine light will not go off.manual indicates engine light will have to be reset but does not tell how to reset.
any advice on how to reset service light woud be greately appreciated.
thanks for your help. trailblazer 2003 v6
Old 12-16-06, 10:16 AM
HotxxxxxxxOKC's Avatar
What kind of car is this? Have you dried disconnecting battery for awhile? Autozone might be able to reset it for you as well.
Old 12-16-06, 10:21 AM
trailblazer 2003
Old 12-16-06, 10:54 AM
try this
Turn on you ignition w/out starting the engine. Press on the gas pedal 3 times, all the way down. NOT TOO FAST OR TOO SLOW. The light should then go off. I found this info on WEBCRAWLER.COM - IT'S ANOTHER SEARCH ENGINE
Old 12-16-06, 03:14 PM
New guy's Avatar
The key is Not too fast Not too slow, if after tried that and the light stills on, turn off ignition key and turn it on and try again, press it all the down and release it all the up for 3 consecutive times if you do it right,the light will goes out.
