'90 Suburban power steering pump removal
Old 12-16-06, 09:36 PM
repo_man62's Avatar
Can anyone tell me how ? Or maybe illustration? Also where is horn relay? E-thing hooked up fuse fine...no horn!
Old 12-17-06, 05:20 AM
As I recall, you need a special puller to get the pulley off, there is a bolt behind the pulley. Should be able to finds the puller most anywhere. Not sure about horn.
Old 12-17-06, 06:31 AM
You'll need both a puller and installer for the pulley.........The rest (on /off the pump is rather simple).........
The horn relay is located in what GM refers to as the "convenience center" ...Under the I/P you should see a bunch of relays/fuses in one big block. The horn relay will be a 3 pronged puppy........Power in one prong and when power is grounded at the horn button, some is then sent to the horn
Old 12-17-06, 09:32 AM
repo_man62's Avatar
Is it like the turn signal stat? Can you be a little more precise on where and what to look for? Thanks
