92 S-10
Old 12-25-06, 09:29 PM
92 S-10
installed fuel pump, fuel pump still not working, i`m not getting any power to fuel pump. can`t find relay or the second fuse box under hood????
Old 12-26-06, 10:44 AM
Check all your fuses... My cousin tore the box off the his 90 chev half ton to fix the fuel pump, found after the fact the ecu fuse blew...
May be nothing, but worth a look...
Old 12-26-06, 02:09 PM
Some older GM vehicles had a small plastic box mounted on the wheel well near the strut tower or on the firewall. It contained both the fuse and the relay. Worth a look.
Old 12-26-06, 06:48 PM
I'm not sure about your make and model but if the Inertia switch gets tripped it will cut off power to the fuel pump.
Find out where the Inertia switch is(if it has one) and reset it just for good measure.
