97 dakota heat please...
Old 12-29-06, 04:32 PM
planning on getting rid of it after winter. all i want to do is manually turn the heat regulator on. fan works, selector works, temp knob doesn't do anything.
Old 12-29-06, 05:31 PM
HotxxxxxxxOKC's Avatar
Have you looked in a junkyard for the whole control panel? I'm sure it wouldn't be that expensive.
Old 12-29-06, 05:54 PM
See if you can get by the glovebox and get your fingers over the top of the A/C Heater plenum.............You may be able to work the blend air door manually to get the desired effect.........On the other hand, you may have to pull back the dashboard if you're not flexible enough
