1996 Pontiac Sunfire-horn relay and rear hazards
Old 12-30-06, 12:53 PM
Exclamation 1996 Pontiac Sunfire-horn relay and rear hazards
The horn doesn't work when the horn button is pushed but the relay clicks and can be heard somewhere under the dash on the passanger side. Disconnecting and reconnecting the battery causes the alarm to sound so the horn itself is good. When the hazards are activated the rear hazards don't work, as well. However, the rear turn signals do work. I have looked the horn relay location up in the haynes Manual and it indicates it is located in the convenience center under the dash on the driver side but when this panel is removed I don't see anything that looks like it houses relays. I would appreciate any help on this very much. I need to get these things fixed so I can pass my state's safety inspection which is due in 2 days. Thanks!!
Old 12-30-06, 01:23 PM
I'd be willing to bet your whole problem is tied up in the alarm wiring from what you've described
Old 12-30-06, 01:48 PM
It's interesting you say that b/c I had to just turn the alarm off for good about 4 years ago cuz it would go off on it's own for no reason. I do believe you're advice was correct cuz after taking a closer look the alarm system is intregrated into the electrical, horn and lights wiring of the car. I had the alarm put in when I bought the car brand new a little more than ten years ago. The place that did it isn't even in business anymore. I have no wiring diagram for the alarm system. Any suggestions?
Old 12-30-06, 02:30 PM
All I can say is try to locate the alarm module.........Remove it wire by wire and reconnect anything they cut along the way..........Then hope for the best
Old 12-30-06, 03:43 PM
Okay... thanks so much. I did find a relay that the alarm, hazards and horn run through. The alarm guys who installed the system seem to have done a fairly sloppy job. Anyway, the new relay didn't solve the problem. I guess I'll look into your suggestion. Thank you again. I'll post back any solution I may find.
