'92 jimmy trailer lights
Old 12-30-06, 04:10 PM
michaeljp86's Avatar
Received 1 Upvote on 1 Post
I have a 1992 gmc jimmy and got a trailer for it and need to wire up the lights. My problem is I cant find anywhere to splice into the wires except taking out the tail lights and splicing them in at the light. Is there some place I missed underneith where the wires run?
Old 12-30-06, 04:21 PM
HotxxxxxxxOKC's Avatar
You will have to find the wiring harness that goes to your lights and tap into them.
You will most likely need a multimeter or circuit tester bulb to determine which wire is what. It's not that hard. The harness most likely is near your rear bumper and frame rail underneith.
Old 12-30-06, 04:33 PM
Thought this was a pickup at first. In your case, the harness nay be running through the inside. Are there any panels you can pull off in the trunk area?
Old 12-30-06, 07:54 PM
I looked all over underneith and only could find wires for the fuel pump. I took the tail light out and the wire runs into a small hole so I cant see where it goes so Im sure its up inside somwhere. It looks like its going to be a pain in the butt. There maybe a panel I can get off and see whats back there. I guess I got another project for tomorrow.
