95 taurus power locks
Hello Ihave a 95 taurus the power locks don't work? I checked man. for fuses locks and widows use same fuse? widows work? fuse is good? So what else could it be?
I would bet on the switch. When this happened in my '93 Silverado, I just bought a new switch from the dealer (should have checked at junkyards first) and snapped it in. It just plugs in like an electrical outlet, no wiring required. I assume they are all pretty much alike. Good luck.
Pecos
Pecos
Are you saying all the power locks stopped working at once? I ask because the door lock actuators themselves are a bad design and often need replacing on an older Ford/Mercury.
power locks
Hey Kestas
Yes they all quit at the same time? even the remote door opener won't work? has a keyless entry to ti doesn't work either? have to unlock with the key! that sucks!
