Honda Accord 1993 Clutch Problem sliping
Old 01-04-07, 09:37 AM
F
Cool Honda Accord 1993 Clutch Problem sliping
I have a Honda Accord 1993 Manual transmission and it seems that when it gets hot the clutch get to short and slips is hard to take off and I let it cool off and it works fine I replace the clutch and clutch master cylinder and still bad I am about to change the Clutch Sleve which is the last part that conforms the clutch system if anybody has expierience this kind of a problem and can give some kind of advice cuz I run out of ideas.
thanks in advance
Old 01-04-07, 03:52 PM
HotxxxxxxxOKC's Avatar
Received 1 Upvote on 1 Post
It's always smarter to replace all parts of the clutch at once so you don't have to tear it all apart again.
Old 01-04-07, 04:17 PM
Ever heard of punctuation in a sentence?? How many miles?? Clutches do wear out, and when you replace anything, it is best to replace everything, as suggested above. You only want to do the job once.
Old 01-04-07, 05:01 PM
I was wondering that myself. Talk about a run on sentence!
Old 01-12-07, 09:29 AM
F
I replace everything clutch, clutch master cylinder, and sleve and it works fine when is cold but soonest the engine get hot or I run it for more the 20 min the clutch starts to get soft and short until slips and is hard for me to take off.
any body has experience a problem like this?
Old 01-12-07, 04:56 PM
the_tow_guy's Avatar
Received 242 Upvotes on 195 Posts
When you say you replaced the clutch did you replace ALL the clutch parts?
Old 01-12-07, 06:34 PM
Have u bled the clutch? If so, sounds like a botched install job.
Old 01-14-07, 09:54 PM
F
done everything replace every part and components and bleed step by step and still not working very wierd.
Old 01-17-07, 10:47 AM
Will this help you?
Don't know if this troubleshooting page helps or not?
http://www.valeoclutches.com/ClutchSlippage.asp
