1995 Chevy Blazer stalls after about 10-15 M=minutes
Old 01-05-07, 07:04 AM
T
Cool 1995 Chevy Blazer stalls after about 10-15 M=minutes
My 95 Blazer keeps stalling after about 10-15 minutes, Starts fine, runs fine then starts to bog down a little and just die, usually when I'm stopped or slowed down and then hit the gas again. After sitting for about an hour or so, it starts right up and then does the same thing in 10 minutes again. It has a brand new fuel pump anf filter (2nd time in about 3 months). Also has new plugs, wires, Ignition Module and Ignition Coil. I'm stumped here, the Cap and Rotor are also fairly new within the last 6 months and there is no moisture in there either. Any help is greatly Appreciated.
Old 01-05-07, 04:49 PM
Received 28 Votes on 27 Posts
As soon as it dies, shut off the key and go to the schroeder valve on the fuel rail. Depress it with a ink pen and see if it has any pressure in it. If not, you have a fuel system problem. A possibility would be the pressure regulator.
Another possibility would an OX sensor. Those take about ten to fifteen minutes to heat up until they start signaling the computer.
Hope this helps,
Bob
