90 Chevy Astro Braking
When ever i brake the steering wheel going back and forth, what would cause this. i just got new brakes and rotors, thought that was the problem but it didnt help any.
Received 0 Votes
And let's not forget the idler arms.........There should be 2 on this unit and they're NOTORIOUS for causing vibration problems.........Anything the brakes start as far as shimmy goes, gets picked up by the loose front end parts.........amplified thusly and then it's HANG ON time........
Does the tire move when you push and pull on it from the 12 and 6 o'clock position? IF it does, then you may have a bad bearing.
My car currently has a bad bearing, makes no noise, but the steering wheel has a slight shimmy in it. I just haven't replaced it yet.
