Anyone Know About This Rims
anyone know anything about these rims and how they fir on and everything, thanks
http://crite2000.zoovy.com/product/WW1005
Which one of your vehicles are they for, Chevy? Reason I ask is for future reference when being towed (hey, it happens). Won't be an issue with the Astro since it's AWD and requires a rollback anyway (can be got around be dropping a driveshaft, of course), but any other vehicle that has this type wheel should only be towed (on wheel lift equipment) in the forward direction. They should not be towed from the rear (unless dollies are used under the front wheels) due to the possibility of one of the front hub spinners actually unscrewing itself. GENERALLY, not a problem, since FWD stuff is towed in the forward direction anyway, but can come into play with RWD stuff or a FWD car with a flat tire on the rear being towed backwards.
I'm Planning On Getting Them For Each Of My Cars.
This You Are Talking About, Does It Make To Much Of A Differenct On How Far The Wheel Comes Out
Whats The Different Between Knock Off And Bolt On
Thanks
Thanks
Last edited by stickshift; 01-09-07 at 08:51 AM. Reason: Removed quoting of entire post
Standard factory stuff is bolt on (lug-nuts); spin off or knock off are aftermarket except for some classic stuff like old Jaguars. On those the factory hub is threaded to accept the big, center "nut" that holds the wheel on. On aftermarket stuff you bolt an adapter onto your factory lugs that accomplishes the same thing. One side of the vehicle has left hand threads and the other right hand, so that as the car is driven there is a natural tendency to tighten the hub. If the car is towed from the rear it defeats this safety feature and it is possible for the hub to come loose (actually unscrew itself) and fall off, followed by the wheel/tire. They are safe as long as you remember the rearward towing restriction.
Ya I hope there are some out there or im going have to really watch my van because i'll be the first to have rims this nice in this town, and this town will do anything for something
Last edited by stickshift; 01-09-07 at 08:52 AM. Reason: Removed quoting of entire post
I just threw up a little in my mouth.....
Spoke rims are junk! I have seen so many people on the side of the road with these junk rims. The spoke tac (weld) inside the rim cracks and brakes constantly on these things resulting in a flat tire and a call to "the_tow_guy".
Spoke rims went out of style, if they even where, decades ago.
these ones have no welds, there the same as reg rims just with spokes
my 2 cents
Looks like a real PITA to keep clean to me brake dust all in those spokes?
I like the old school Centerline wheels myself all you old guys know what I am talking about.
Sssh, Mark; let's not discourage anything that could lead to a tow!
My main beef with rims of that type is not so much the rim or its contruction, but the tires with next to no rubber involved that are mounted on them. Walk up to 75% of the ultra-low profile tires you see on cars with a tire gauge and I can just about gaurantee they are dangerously underinflated. Good news for the people who make and sell them because they wear out and fail faster than a conventional tire. Hit a significant pothole and you can bend one the rim too.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=TRD%2D7129&N=700+%2D152367+115&autoview=sku
