1998 toyota Tocoma wiper motor
Old 01-09-07, 12:03 PM
G
Hello, This morning my wiper fluid barely got to the bottom of the windshield, I assume the motor is going out. I checked and it appears I just need a new motor....couldnt find a pump? I assume this is one in the same? Is this a simple fix? A couple wires/bolt. Do I need to disconnect the battery before I install? Thanks for any advice.
Old 01-09-07, 05:12 PM
HotxxxxxxxOKC's Avatar
As a safety precaution, always disconnect battery before doing electrical maintenance.
This pump should be mounted to your firewall area, and a simple unbolt and unhook connector should work.
Be careful pulling of the wiper hose as this may stretch and/or tear. You might as well pick up some of those while you are at the store.
Old 01-09-07, 05:21 PM
G
Received 2 Upvotes on 2 Posts
Before you do any major work, disconnect the hoses from the squirters and test the flow. If you get a good flow of washer fluid, the nozzles may be clogged, which is not uncommon. If you have a very small diameter piece of wire, you can often reopen the nozzles.
Old 01-10-07, 02:46 AM
temp
What was the outside temp? if it gets to the point of a frezze it can do that.You will need winter formula cleaner.
My Tacoma has done the same thing when very cold.
Old 01-10-07, 06:41 AM
G
Thanks for the input. Temp is well above freezing. Ill disconect the hose the try to squirt...if same result...I will replace motor
