2004 Dodge Grand Caravan wierd noise
Received 0 Votes
V6, automatic transmission, about 90K miles. Pretty new tires.
The noise is a whirring sound coming from the front passenger side. It sounds to me like it is coming from the wheel well. It is present all the time, but gets severly loud when turning. This noise has increased in the last 6 months, seems to be getting worse.
Any idea to the cause? Any idea if it needs fixed?
thanks!
thanks!
Sounds like a wheel bearing issue and needs to be fixed. You do not want to have a bearing seize up on you. It will cost you a ton more money.
If not bearings, power steering.
