92 ford ranger 2.3 fuel relay?
Received 0 Votes
fuel pump continues to run after ignition switch is off.have to unhook batt. is there a relay and where is it located? xlt short bed reg cab. 4 speed.
Received 0 Votes
On Rangers usually the fuel pump relay is located somewhere close to the battery under a little black box(abuot 1" by 5"), undernieth this box you will find 2 or 3 relays. The green one is your fuel pump relay. Get a new one at your local parts houe. P.S. This is a very common problem with Ford trucks. MAXCHEVY
Received 0 Votes
92 ford ranger fuel relay 2.3
tks. for the reply, the green 30 amp fuse is in the box beside battery, the info i need help on is that the fuel pump or relay ? runs all time unless i diconect the -terminal. is the rely valve, pump or whatever bad?? where and what is the fix and or suggestions
Received 0 Votes
Max isn't lyin to ya bud.................Usually by the outer fuse panel wherever they put the ALDL..........there will be 2 somewhat large square relays sitting side by side. The black one is the EEC relay, lights up your computer systems.......the green one is the fuel pump relay
