heater core
It's a long job. It requires the draining of all the coolant, then removing most if not all the dashboard. The core is usually located behind glovebox. Remove anything you have to, to get to the airbox. You will see the two radiator hoses going into the firewall, the core is usually behind that. It's not going to be easy.
