Cadillac oil change
Old 01-14-07, 09:11 AM
Unhappy Cadillac oil change
how do i remove the message "Change engine oil - service engine" that
continues to pop up on '95 cadillac.
Old 01-14-07, 09:49 AM
oil light
if you have a owners manual read it it will tell you how to remove the message or call the dealer they may tell you how to do it
LouBazooka's Avatar
change oil light
well first make sure you actually did the change the oil and filter , on newer chevys (2000 and later )you open the ignition switch and pump on gas pedal 3 times within 5 seconds, close ignition switch if you see light flashing on dash board that means system has been reset.
