1999 camry window
Received 0 Votes
1999 camry window
My driver side window rolls down by itself intermittedly usually when I make a left turn. All other windows are working fine. It's cold and raining. I need help quick
If it's hand crank, the winding mechanism is probably going bad. If it's electric, it would sound like a wire with an intermittent short. You could start checking by popping the window switch out and checking for a loose wire.
Received 0 Votes
jiggle the wires
jiggle the wire harness were it goes in to the door, If you open the door you will see it by the hinges. might have a short there.( make sure car has power applied)
