1997 T-Bird Fuel Filter
I had no trouble locating the fuel filter and taking off the old one until I tried to pull the old filter from the fuel line. The rear line came off easily, but the front line will not come off. Any suggestions?
No suggestions
You must be trying to remove the original factory filter! They were installed with a one-way design connector constructed of metal. There's a special tool for this. I don't have such a tool, so it took me about an hour to remove such a filter when I came across it on a 95 T-Bird.
Once the original filter is replaced, the next filter changes are easy.
It's been a number of years, and I'm working from memory, but I believe I took a small screwdriver and kept poking at the connector, pushing back the tiny flaps, and tugging at the joint until it came off.
