spare tire wont fit...exactly
Old 01-16-07, 05:51 AM
coops28's Avatar
I have a 2001 ford f150 that I bought without a spare. It has 17" wheels. I thought I could use my spare from my 1994 f150 with 15" wheels. It almost fits. Almost. Can I open the holes up a little to make it fit? Or will that ruin the wheel? also, the mechanism that holds the spare tire in place is frozen. Can I fix it or should I get a new one? Thanks.
Old 01-16-07, 07:02 AM
Don't mess with the rims. These are highly engineered safety items. For example, on steel rims, you'll notice the mounting holes bulge out a bit. That's so they act as a belleville spring to maintain proper tension and clamp load on the wheel stud when the lug nut is torqued down.
Get the proper rim from a junk yard. Get a used tire for spare from either the junk yard or a tire dealer. Use PB Blaster to free up whatever is stuck in the spare tire holding machanism, then treat with an antiseize compound so you have a workable spare when you need it.
