Coughing Dodge V10
Received 0 Votes
Coughing Dodge V10
I only put about 5000 miles on this Dodge 1996 2500 V10 (40K miles) a year so as you can see it sits a lot. It had this coughing spell before these upgrades but I did not do these upgrades to cure the problem. Headers, K&N Aircharger Air Intake Kit, and a larger throttle body.
What the problem is after over 3 days or longer setting or in cold weather (engine cold) it can not take much throttle when first started to roll down the road, it will act like and older model with a vacuum spark advance that is unhooked. I have found 2 ways to clear up this problem, 1, rev the engine in neutral to about 2K-2.5k, 2, just let the engine continue to warm up a bit. Never have looked into the problem because it is such a small problem and can be over come. Would like to head it off so as in the futrue it doesn't get worse.
RRR:
It's difficult to say for sure. The water temp sensor is the only thing I can think of that works to provide a rich mixture (for the cold running) and then gradually leans it as the engine warms up. A cold engine with a mixture too lean will run more normally at a higher rpms.
Assuming you have a mixture that is too lean, the engine would warm internally very quickly in terms of the heads and combustion chamber. The lean mixture may be enough to sustain the engine after running it briefly at the higher RPMs.
This is all assuming a fuel injected engine.
Hope this helps,
Bob
Hope this helps,
Bob
