96 cavalier were does the thermostat go
Old 01-21-07, 11:03 AM
were does the thermostat go on cavalier. help
Old 01-21-07, 12:32 PM
HotxxxxxxxOKC's Avatar
Follow your top radiator hose. At the other end of that, will be the thermostat. Usually held on by 2 bolts.
Old 01-22-07, 07:25 AM
G
Received 2 Upvotes on 2 Posts
Actually, on the 2.2 engine it is in the lower radiator hose. If it's a 2.4, it gets a little more complicated. Go to the following web site and put in your car's info. Then go to their maintenance guide section and they have pictures and step by step on replacing your thermostat.
www.autozone.com
Old 01-22-07, 08:11 AM
the_tow_guy's Avatar
Received 198 Upvotes on 158 Posts
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/19/1a/5e/0900823d80191a5e.jsp
Old 01-25-07, 05:55 PM
T
If you have the quad 4 engine(I think it's a 2.4), it's under the exhaust manifild. look between the #2 & #3 ports, straight down and there's 2 or 3 bolts going straight down for the top of the housing. It's a sad situation. Maybe try backflushing the heater core first. I live in northern Minnesota where you use the heat 10 months out of the year. Your car uses a factory heater core with coolant flow tubes that you could barely pass a thread through. I usually remove the hoses from the heater core and put the garden hose on one end then the other until the water runs clear.That will get you through the rest of the winter.
