95 Jeep GC Windows malfunctioning
Old 01-25-07, 10:12 PM
A
1995 Jeep Grand Cherokee
Had a sudden change when both a rear directional lamp went out and the power windows stopped working. When the lamp went out (on the left), the left directonal was blinking (on the dash) much faster than it normally does. Replaced the bulb and now it is fine, but windows still don't work.
Replaced the circuit breaker on the fuse panel (inside front pass. door) with no luck. I don't see any indicator that the fuse panel under the hood controls the power window circuit....any ideas for the next step?
Old 01-26-07, 07:43 AM
windows
well just a guess but ck if you have power to drivers master switch also make sure that window lock isn't on then ck grounds
Old 01-28-07, 07:19 PM
P
These have a problem with the wires between the door and the body breaking.
Old 01-28-07, 10:53 PM
A
even if it is all the windows and not just one affected? that sounds like a central problem?.....
