Repost 1988 Dakota Steering
Received 0 Votes
I am reposting this because I reffered to some of the parts by their wrong name. Maybe this will help someone else to help me. I believe I have this narrowed down to two possibilities. When the truck is turned off, I can turn the steering shaft and it seems very stiff with little play. However, when I start the vehicle, and turn the steering shaft, it jumps several inches in each direction, having excess play and slop in the steering. While driving it jumps from left to right for a few inches as if there is no contact with the internal steering components. This truck has power steering. The steering system is reffered to as a manual rack and pinion. There isn't fluid leaking that I am aware of. I was wondering if there is a bushing or fitting on the steering gear (where the shaft meets the gear ) that could be worn? Other guesses I have are 1. Rack n pinion system needs replaced or 2. Steering knuckle needs to be replaced. Any info will help. Save my work truck.
It's likely the rack and pinion. Have someone move the steering wheel while you watch or hold the shaft from under the hood. That would tell if you have a bad steering knuckle.
However, from what you've described, think in terms of the rack/pinion assembly.
Hope this helps,
Bob
Hope this helps,
Bob
Received 0 Votes
there is lots of possible causes for steering slop would start at the wheels by jacking each front wheel up and wiggling side to side if excessive play is found its probably from a tie rod. then move on to checking the steering shaft and gear box for excessive play to find out where its coming from.
Received 0 Votes
I have an 01 Durango and it's rack and pinion................88???? May be box?????........Not sure........But I'd jack each wheel up and check for looseness in the bearings and the ball joints as well as the tie rod ends and other steering linkage...........Dodge had a problem with the ball joints and my (wifes) truck is now warranteed for 100K miles on certain suspension parts.
Received 0 Votes
UPDATE= It turns out that the rack n pinion and gear box need replaced. A job that I would attempt if it weren't 10 degrees here. So I decided it wasn't DYIable. Its in the shop. Thanks for the replies.
