02 Toyota Camry a/c trouble
Help! a/c light blinks and a/c blows warm air when this happens. I had it checked out by a garage and they said levels were fine but I have an "electrical problem." Recommended I take it to a dealer. No can do! Not in my budget. Any recommendations? Thanks!
Sounds like one was working on last week...........You from Fl?????...........Anyhow.....I had a Camry just like described. Had power to the compressor relay and power to the trigger side of the relay. If I jumped the relay, I could turn on the A/C compressor so up to that point was good........The ground on the trigger side was the ECU so I checked state display to be sure the ECU saw A/C request from the heater/A/C control head, it did.........AT THAT point I recommended the dealer as it became obvious te ECU was not turning on the compressor as requested........ECU problem, replace/reflash???.............And I checked bulletins on this too, didn't find any............Anyone have any ideas?????
