Heater Switch
Received 0 Votes
Heater Switch
I replace the heater switched on my 90 Safari because the contacts were burnt. A couple of days ago i went to turn the heat on and it wasn't working. Does anyone know what would cause it to burn the contacts out like that?
Thanks
Thanks
Received 0 Votes
yes the new switch is burnt. a friend of mine told me to put resistors on the wires to prevent the contacts from being burnt...it doesn't sound like a good idea but i could be wrong...i don't plan on having the van for to much longer but i would like to have heat while i still have it
Received 0 Votes
Fan motor probably on its way out and drawing too much current (although I would have thought the fuse would blow first; did you replace a fuse with one of a higher rating for this circuit?).
Received 0 Votes
On the beam Bob..........Check the resistence in the blower motor. Also check the resister block that gives the motor its different speeds. If it keeps smoking switches the block oughta be toasted too..........One other thing........Make sure the contacts at the switch are clean and tight......After one smokes, the wires and connector get pretty ugly
