speedometer cable
speedometer cable
My son has a 92 Geo Storm. When driving, the speedometer goes all the way up and stays there until he puts on brakes. Before it would go up and down and I put some grease on the cable and it started working again. Today, I put some grease on it and it did nothing at all to solve the problem. Does it sound like I need to replace the cable itself or possibly something else? thanks.
speedo
Usually when they act like this the bushings in the head are worn and the rotating part rubs the part on the needle,thus the minute the cable turns it takes the needle "all the way" no you cant get the bushings. There are some speciality shops that repair them but it would be a lot cheaper to get a used one. Good luck Tom
