wiper transmisson
Old 02-01-07, 01:15 PM
C
wiper transmisson
i have 1994 taurus. wiper transmisson arm has came off or broken. i can not get to it or see it. does anyone know how to gain acess to arm. this is not the end that goes to wiper motor,it is the end that is by drivers side fender.thanks for any help!
Old 02-01-07, 02:41 PM
P
what is the problem?
being more specific with the symptoms might help you
To get to the linkage, remove both wiper arms and then remove the black plastic cover at the bottom of the windshield. You may need to open the hood and front doors and peel back weather stripping and hunt for the screws.
To get to the motor, working under the hood remove the black plastic cover screwed to the firewall.
Old 02-01-07, 03:31 PM
C
wiper
passenger side wiper does not work. wiper transmisson arm is broken are has come loose on drivers side not the arm that connects to wiper motor. i can reach part of my hand into a hole and grab the rod that has came loose but there is no way i can work on it or see it. i have the leaf cover removed and the wiper arms off, but the hole is still to small to get my hand through.this arm connects to right side wiper goes across car to drivers side fender then connects to another arm that goes to wiper motor. the only other solution i can come up with is to remove the whole assembly so i can repair that end,
