Broken Door Handle - 1995 Toyota Camry
Well, things are starting to go on this car, but I still love it.
The other day the interior door handle on the drivers side door snapped off! Its virtually impossible to operate this way.
I have no idea if this is something that can be fixed, either by myself or at the dealership? Are parts still available for a car this old?
Oh yeah, parts will be available and it is repairable. Common failure item along with exterior door handles which will sometimes break off (wife's previous car - '95 Camry - we eventually replaced both inside front handles and the driver's side external handle). If you're handy, it's DIY-able, but involves taking the interior door panel off and fiddling with the linkage. It's a little tricky, but not rocket science.
door handles seem to be a Toyota weakness
I would suggest OEM replacement from the dealer , they can order it if they don't stock it
its a pretty easy thing to install yourself or any mechanic can do it for you
I agree, hit the dealer. Not a candidate for a junkyard replacement unless you like doing it over and over. I seem to recall that the price wasn't TOO outrageous. If you ever have one of the external handles break off, the new ones even come painted.
Wow. Cool! I wasnt expecting this. Yea, its so funny you all mention the problems with the Camrys. Since you mention it, 3 of 4 of the interior handles have broken in the same spot, so it makes sense that there's an issue. Great, I dont want to mess w/it, so I'll go to the dealership. Also have a speedometer that stopped working a few months back !
Buy the parts from the dealer, but for goodness sake find a good independent to do the work. Your wallet will thank you.
Speedo problem could be vehicle speed sensor; that's fairly DIY-able - one connector and one screw holding it in the transmission housing. Trying to remember if that will set a check engine code and can't. Might want to get it scanned for codes just in case; AutoZone will do it for free.
