heated seats
Received 0 Votes
heated seats
I installed heated seats in my 2004 f-150. I just tapped them into the fuse box temp, I need to find out where I can tap them into an ignition source . Right now I need to make sure that they are off when I leave the truck, or they will stay on and drain the battery. Anyone know where is the best place to hook them up to an ignition source? Thanks
Find an accessory fuse. These only turn on when vehicle is on. Find a fuse already in there, that is also rated for the amps your seats require, and share that fuse.
