headlight switch
Old 02-04-07, 08:56 AM
Unhappy headlight switch
how to remove old headlight switch for a 89 chevy suburban and install new one
Old 02-04-07, 10:07 AM
headlight swicth
you need to remove your cover plate with a small flat head screw driver, the switch should have two pressure prongs on the side of the swicth, slide a small flat head screwdriver into one side (were the prongs are) and then on the other side, wiggle the swicth out. there will be a plug on the back of the switch, with the same smalll flat headed screwdriver, slide it under the clip and pull switch off. Hope that helps you.
Trackbacks are On
Pingbacks are On
Refbacks are On
