2000 Neon Stalling
Old 02-05-07, 07:00 AM
D
2000 Neon Stalling
This is for a friend, so I may not have all the details needed. I am just looking for any ideas.
In Nov, the plugs were changed to correct an intermittant stalling (while warm) problem. It seemed to correct the issue. Now, it is doing it again. After a short warmup period, it stalls from time to time (had not done so cold). Gas mileage seems to have gone to the birds as well.
There is no check engine light (according to the owner). Any ideas? (I would love get more info, but the owner is not very good at describing symptoms).
Thanks
Old 02-05-07, 10:25 AM
HotxxxxxxxOKC's Avatar
Has the fuel filter been changed? This will stall cars.
Old 02-05-07, 02:18 PM
the_tow_guy's Avatar
Received 184 Upvotes on 146 Posts
Also if you browse the other threads running in the auto forum you will find several that address the same or similar problems; most of the possible culprits will be addressed.
Old 02-05-07, 04:14 PM
Pendragon's Avatar
Received 2 Upvotes on 2 Posts
Crank Position Sensor.. about $300 repair at the dealership.
If that is indeed the culprit, it will eventually leave your friend stranded.
ref: my own 2000 neon
