remove heater fan on gmc safari
Old 02-05-07, 10:13 AM
It's a 1989/w air, 4.3 motor.
How do you get the heater fan out of the truck? We get it all unscrewed but can't get it out. Is there a trick to it or do we have to start taking other things apart?
Thanks
Old 02-05-07, 10:23 AM
HotxxxxxxxOKC's Avatar
The HVAC housing will be bolted on the firewall as well as the inside. Look on your firewall for additional screws.
If you have A/C, you will have to remove the A/C linesm along with heater core hoses.
It's a major job.
Old 02-05-07, 10:49 AM
Thanks,
I should have known , it was going to smooth. Wire came off easy, all the screws that held the fan were easy. Definatly has to be a weekend project. Thanks for the heads up.
