1999 Ford Ecoline Van rear vent blow cold air
Received 0 Votes
My 1999 16 pass van over head vents only blow cold air. the heat is on up front and i turned the knob over head in the rear to heat, but still only cold air?????? any help.
There probably is a bad blend door actuator. I believe these vans have 2, 1 for the front, 1 for the rear. If this is the case. you have a major job to tackle. These actuators are under the HVAC assembly and under the dash.
