Broken stud, Subaru catyletic convertor
Hello
If you can help please.
What is the correct way to remove a broken stud and replace it .
Thank you very much, Bob
if the stud is still sticking out try puting to nuts on it tighen nuts together then turn. you may need to heat the area around the stud with torch if the stud was broke due to trying to remove good luck
