Suzuki Swift cold start
Received 0 Votes
Hi
Can anyone help 2002 suzuki swift will not start when weather is cold it has a automatic choke soon as there is any frost it will not start till the weather gets warmer.
That will be fuel-injected and won't have a choke like on a carbureted car. First step will be narrow down if it is a fuel problem or an ignition problem (there are other possibilities, but these are the basics). When it's in the no-start condition, pull either the coil wire or one of the spark plug wires and see if you are getting spark. Fuel problem check will start with checking pressure, but try the spark check first.
