Broken metal stud
Old 02-07-07, 09:11 PM
R
Broken metal stud
The stud is broken below where I can thread a nut . Do I drill it out and re thread it or are there threaded insert's . Bob
Old 02-08-07, 07:23 PM
1
install 2 nuts on stud tighten nuts together then loosen first nut it should turn the stud and remove it
Old 02-09-07, 08:52 AM
F
If the stud is broken off and you can't get to the threads to do the 2-nut trick as in the last post, you need to use an easy-out to remove the stud. Easy outs are sold at Sears and auto parts stores. They work by being inserted into a drilled hole in the stud and turning the easy out backwards - the easy out has left-hand threads that engage the stud/bolt and turn it backwards to unscrew it from the mating part. Then install a new stud.
Old 02-09-07, 08:01 PM
R
Easy out
Thank You : Formula
