coolant fan runs all the time
Old 02-08-07, 04:54 PM
Question coolant fan runs all the time
I have 97 Z 28 Irock the coolant fan runs all the time, even after the key is shut off . what is the problem and how can I fix it.
Old 02-08-07, 08:42 PM
You might have a bad cooling fan relay. Follow the wire from the fan and it should go directly to the relay socket. If you see another relay nearby that looks the same, pull it out install it into the socket with the questionable relay and see if that solves the problem.
