replacing front wheel bearings on 1981 Volkswagen Jetta
Can anyone give me basic instructions on the replacement of the front wheel bearings for my 1981 Jetta. I have received quotes to replace them ranging from $350 to $450. Any help is greatly appreciated!
Most vehicles require the following basic procedures:
Remove tires
Remove brake calipers
Remove large cotter pin from spindle nut
Remove large nut
Pull rotor off
Bearings will be in the hub.
It should be fairly easy. I don't think your bearings are pressed in so they should be removed quite easily.
Remember to use plenty of packing grease for the new ones.
Remove tires
Remove large nut
Pull rotor off
I have an '85 Jetta (A2), here's what I do for VW pressed in bearings (front):
Loosen wheel nuts remove hub nut cap/cotter pin
Loosen hub nut
jack up car
remove wheels
remove hub nut
remove brakes/secure lines/secure caliper
remove disc brakes
impact off the front shocks
loosen a-arm nuts
remove CV arm bolts (need special 12-point allen wrench and a helper)
remove hubs from arms
take hubs to machine shop along with new bearings
machine shop presses in bearings
reassemble in reverse order
re-align car
Smile and have a beer!
VW rear bearings for A1 and A2 are not pressed in and can be redone without the aid of a machine shop.
Loosen hub nut
jack up car
remove wheels
remove hub nut
remove disc brakes
loosen a-arm nuts
re-align car
Last edited by the_tow_guy; 05-31-07 at 04:32 PM. Reason: Removed external link; not germaine to specific Q&A.
Taz,
Hopefully they have replaced it by now. This thread was from February. Also, be careful of posting links to other forums. You only can post a direct link to the repair and not just the general website.
