95 olds cutlass tranny
Received 0 Votes
I just bought a 95 cutlass runs great but I have no 1st or overdrive 2nd and 3rd work could the problem be a control solenoid? also where are they located? any help would be appreciated.
Received 0 Votes
Is it an electric shifter????...........The solenoids will be in the valve body.. the connectors will be side or top.........I'd almost want to be lookin for a fuse.......like the unit isn't getting power to run the solenoids and is in default (we used to have that problem with Jeep when they first came out with the Aisan/Warner 4 spd).........If not that you're gonna be lookin inside the case
