1987 dodge tranny replacement
Old 02-14-07, 04:25 PM
G
hello,
lost reverse the other day in my van ..the cable was good... so i took off
the pan ..and everything was messed up ..so i replaced the valve body with another one.. ..after that i got my reverse back but no drive now.
.. so i switched back to my old one same thing.. i do have drive but it has to rev extremly high ..for about a min before it moves a little.
so 2 questions .. what the heck went wrong?
there is only 2 pipes things that go into litle holes i made sure on the last time they were going up ..? is it possible it had a ring of some type.
but that neither the new /used one had it on the other tranny that i notice nor this one.
or ./ and..
what other years of transmisions can i put in a 1987 2.2 ..will a 2.6 fit 3.x
will one from a 2.2 car fit?...and what years .. from 1984 -1991 are they all the same tranny?
------------edit.
sorry, its a dodge caravan 1987
thanks
Old 02-14-07, 04:48 PM
HotxxxxxxxOKC's Avatar
Received 1 Upvote on 1 Post
Sounds like you have a shredded driveshell. Was there alot of shavings on the magnets?
Old 02-16-07, 09:13 PM
G
Hi thank you so much for taking time to suggest something..
however no metal shavings on the magnet.. some sludge looking stuff thats about it..
i was going to try to take off the valve body one more time 2morrow and pound in the pipes with a hammer or something heh....and if that doesnt work
try to get another tranny. from the wrecker.. ..
my drive worked good until i took off the valve body.. accept something did happen.. before hand.... i had gone to the front of the van.. to manual shift it ..without the cable on ..still no reverse ..but then it shifted into first went for a small ride.... i tried to shift the shifter lever back down .. but it started to make a grinding sound... but after that i had pushed my van back out where it got stuck..and i still had drive......
Then the next day i took off the pan... the lever part that goes to what i can guess is the park thing... was wedged in that location.
..its a long bar ..with a spring that extends another peice of metal..if that makes any sense to you. .. .
is it possible for me to find the driveshell thing? to see if thats the problem ..is it possible to fix easy ? /not having to take the entire tranny off.
