quad 4 pont grand am engine
Received 0 Votes
i have a coolant leak not from the water pump which i think is on the dvrs side. the leak is coming from the pass side of the eng it is not the heater core. can someone please tell or send a diagram of all cooling parts for that engine
thank you
thank you
Doubt you will find one online. You can get a Chiltons or Haynes manual and those might tell you more.
Look at all the hose connections and the hoses themselves. If hoses seem fine, then the freeze plugs on the engine block might be leaking.
