Cooling fan in Honda Odyssey won't shut off
Old 02-17-07, 11:32 AM
I have a 2002 Odyssey. It's cooling fan won't shut off after I turn off the engine. I called the shop and they said it is normal for it to run for up to 20 minutes to cool off the engine. I let it run for at least that long, and it is still going. I had to unplug the battery, and 1 hours later after it sits in my cold garage, the fan still runs when battery is re-attached. Is the temperature sensor malfunctioning? What else could be wrong?
Thanks.
Old 02-17-07, 01:50 PM
G
Received 2 Upvotes on 2 Posts
The sensor is one possibility. The other, if the sensor controls a fan relay, is that the relay is stuck in the on position. If you can back track from the fan motor, and the power wire goes to a relay, that's where to start checking. A simple volt meter would be a big help.
Old 04-18-09, 08:08 AM
Answer?
Did you ever get an answer to this issue? I am having the same problem with my 2002 odyssey.
Thanks
Old 04-18-09, 08:41 AM
K
Usually it's a stuck relay. Try to find where the relay is located. Next time you run into this problem, tap the relay and the problem will probably go away. Then you'll know to replace the relay.
