crankshaft sensor
Old 02-17-07, 12:55 PM
W
crankshaft sensor
1999 chevy cavalier 2.2 engine
P0301 cylinder 1 misfire
P0335 crankshaft position sensor A circuit malfunction
replaced sparkplugs and wires and ignition coil
still shows both codes
Is the P0335 something we can do ourselves?
Do we replace it? and is it located under the ingition coil?
Old 02-17-07, 02:17 PM
HotxxxxxxxOKC's Avatar
The Crankshaft sensor is what caused your misfire codes.
This sensor mounted on the engine block neat the crank.
Yes, this can be replaced by yourself.
