oil change for 1999 econoline van
Old 02-19-07, 03:27 PM
T
my ? is how many quarts does it take when you change the oil, the dip stick handle broke off so i dont know if i push it to far down or not far enough when i stick it in, so i thought if i knew how many quarts it holds when i do a oil change i can then judge the dip stick.
Old 02-19-07, 03:59 PM
Most engines were 5 qts with filter change. But my 00 Chevy took 6 qts for the V8
Old 02-19-07, 09:08 PM
LouBazooka's Avatar
what size engine ?
see what size engine you have and look it up on google or owner's manual
my duramax 6.6L Diesel takes 10 quarts, wife suburban's 6.0 L takes around 6.5 so every engine is different, don't go by the " 5 quarts" rule.
Old 02-20-07, 09:10 AM
K
The E150 with 4.6L engine uses 6 quarts including filter. Autozone.com is a good place to find specifications for your particular vehicle.
Old 02-20-07, 11:34 AM
daswede's Avatar
Autozone. Then to the junkyard.
