Mazda B-2200
Old 02-19-07, 06:00 PM
R
Mazda B-2200
I now have a Weber carb. on it , but the hose that runs from the head cover to the carb seem's to let to much oil into the carb. do I need that hose connected to the carb ?
Thank you again Bob
Old 02-20-07, 06:02 AM
the_tow_guy's Avatar
Received 241 Upvotes on 194 Posts
Only hose running from a valve cover to the carb/intake should be the pcv. Yes, you need it. How many miles on the engine; you may have some worn out rings causing excess blow by.
