brake pads on 2000 explorer
Old 02-20-07, 08:27 AM
MPC's Avatar
MPC
MPC is offline
Cool brake pads on 2000 explorer
How do you install front and back brake pads on a 2000 explorer
Old 02-20-07, 11:21 AM
the_tow_guy's Avatar
Received 184 Upvotes on 146 Posts
That's a tall order, mpc. Here's some help:
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/0b/ce/8c/0900823d800bce8c.jsp
Old 02-20-07, 11:28 AM
HotxxxxxxxOKC's Avatar
Pretty easily actually.
Remove tires
Remove the two smaller bolts that are facing inwards
Slip caliper off, careful not to damage brake line
Brake pads will just fall out with a little push of your fingers.
When install the new pads, remove the brake reservour cap
You will most likely need to have a C-clamp and a thing piece of would so you can compress the caliper piston back into the caliper. Remember, new pads are thicker, so that is why this needs to be done.
With piston back in, install pads following manufacturers instructions.
Pump brakes a few times to reseat the pad/piston
Bed in the pads following manufacturers instructions.
Also, with those two smaller bolts removed, one side of the brake bracket will stay in vehicle and the caliper will come off.
If you remove the two larger bolts, the whole assembly will come off. It doesn't matter which way you do it though. It's fast taking the two smaller bolts off.
Old 02-20-07, 06:43 PM
H
i recommend buying a Haynes or a Chilton's manual ... these things are great for rookies, like me, .. step by step though not always perfect they'll get you in the ball park.
