supercharger no go
supercharger no go
i have a 92 thunderbird sc that recently lost it's sc-ness. it happened just after i changed the oil in the supercharger unit. the old oil was pitch black, thin, and smelled like burnt garbage. i syphoned out as much old oil as i could, with a turkey baster( as per the haynes manual) and noticed within two days that every time i kicked it in the guts, it stuttered and shook. violently. the oil level is right, the oil type is right, the oil changer is confused. otherwise, the car runs fine. any ideas? very cool sight, by the way. thanx
The S/C is probably toast. If the oil smelt burnt, that is a bad. Only option from here would be get S/C rebuilt, or get new if they even have them available anymore.
sounds like something happen to the charger does it get up and scoot when you press on the gas? notice the Boost? if it shakes it could be a wire off 1 of the spark plugs sounds silly but under load it would prolly do that and then some im no expert but theres a few cool sites on the web that could help you
ya might try SCCOA a great site and plenty of help i know i own one
