Brake lights won't work
Received 0 Votes
Hi guys. I have a 94 Camry who's brake lights just quit. I've checked all the fuses I could find, and they all had continuity. I'm thinking it might be a relay?.... I'm looking for another fuse block <besides the one under the hood>. Any ideas?
Received 0 Votes
control module
If memory serves me right I think your Toyota has a control module (a electronic box) for back lights. Think it is someplace in the trunk. Do a google search to make sure.
Received 0 Votes
Thanks for the idea....I've actually got them working again, wiggled some wires by the fuse block <under dash> and they started working again....amazing lol. Just hope I can find the loose connection tomorrow.
Received 0 Votes
Should be another fuse box in the left kick panel........Sometimes one in the right too.........Do you hear a click when you depress the brake pedal????..........If all else fails....test light to switch
Received 0 Votes
Actually, there isn't a click when I depress the brake pedal, but <was> previously a click when I tried to shift out of Park, and the shifter button wouldn't press in all the way, so it couldn't be shifted. I started to think that the brake pedal safety switch was shot, so I had to rig the manual override switch in order to shift out of park. Do you think these problems could have anything to do with one another?
Received 0 Votes
when did problem start
Did problem start after your bypass? Also if the switch functions as a multifunction switch for saftey interlock and lights I would replace it.So yes it is possible they are connected.
Dont think a switch is that much money but if it is you can always go to wrecking yard.
Received 0 Votes
Found the problem: bad brake light switch @ the pedal.....replaced it, and the lights work like a champ! Also, the shifter safety switch activates normally now....2 birds w/ one stone. The old switch would work about once every 5 times....gummed up I guess, or just wore out. Thanks to all who replied!
